BOSS 302 Exchange
September 09, 2010, 09:50:37 am *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: A price is required on all items listed "for sale" in any forum/thread/post.
   Home   Help Login Register
Pages: [1] 2  All   Go Down
  Print
Author Topic: New Part Picture?  (Read 6517 times)
Bigdee
Senior Member
Offline Offline
« on: June 11, 2005, 09:33:40 am »
I have a new part that I had made for you guys to see and buy, but I don't know how to post the picture for it! Help would be greatly appreciated!
Logged
Darrell
lovehamr
No Life
Offline Offline
WWW
« Reply #1 on: June 11, 2005, 09:36:55 am »
If you want, send it to me and I'll post it.
Steve
P.S. e-mail is lovehamr@yahoo.com
Logged
Super Land Shark!
Bigdee
Senior Member
Offline Offline
« Reply #2 on: June 11, 2005, 09:41:56 am »
damn that was quick! What is the email address?
Logged
Darrell
Shissler95
Senior Member
Offline Offline
« Reply #3 on: June 11, 2005, 10:26:15 am »
send picture to Shissler95@aol.com and I'll post if for you.
Logged
img]http://members.aol.com/Shissler95/sig2.bmp[/img]
Bigdee
Senior Member
Offline Offline
« Reply #4 on: June 11, 2005, 11:14:18 am »
http://members.aol.com/Shissler95/plates1nomore1.jpg
This is an aluminum carb spacer plate to replace your existing Boss 302 Ford plastic carb plate. I get the plate already made for a Holley, it is ?? thick then I modify it to match the original Ford plate but WITHOUT the nipple for the PCV valve hose. If you have an old plate that is cracked and still have it, you can use that nipple for this plate. The plate is pre-machined to except the nipple. Thickness of the original from Ford is 5/16? but I can make the thickness to any size between 5/16? thick to ?? thick. I have made (3) of these plates already to the thickness of .380 (3/8) and the owners have had no problems, NOTE: (they were installed on Shaker Hood cars). To look more original, you can paint the outside edges black and who is going to know, as it is hard to see the plate after the air cleaner is on!
 If you are interested, and tired of the Ford plastic plate cracking on you and having leaks, the price is $38.00 shipped. You get the aluminum spacer plate (made to your specified thickness) and 2-base gaskets.
Note: I could make a plate thicker than a 1/2" if you need one, let me know what thickness you want an I'll see what I can do for you!
Email me at bigdcobra@verizon.net
If someone has a source for making the nipple out the front, please let me know!
Logged
Darrell
icecreamman
Needs A Job
Offline Offline
« Reply #5 on: June 11, 2005, 11:17:06 am »
Logged
Bigdee
Senior Member
Offline Offline
« Reply #6 on: June 11, 2005, 11:20:13 am »
Thanks, Ice!
Logged
Darrell
Rob
Senior Member
Offline Offline
WWW
« Reply #7 on: June 12, 2005, 07:44:32 am »
I have one on my car for about a year now, and this is the way Ford should of made them.
It seems like you have to get a new plastic one every time you take off the carb. With the one that Bigdee makes,I have had the carb off about a dozen times or so and this thing is as strong as day one.
I did?nt paint mine black as you would have to stand on your head to see it.
Also, I have a shaker car and everything fits fine.
The way I see it, why spend the same amount for a repop piece of junk, when you can have something that will last a lifetime for the same money.
Logged
9F02G196848
Global Moderator
No Life
Offline Offline
WWW
« Reply #8 on: June 13, 2005, 06:12:06 am »
We also put one of these on the problem red car we were working on. Works great with no worry of potentially breaking or cracking the repo units. The original Ford units aren't too bad, but still take a chance of a vacuum leak.
Logged
Derrick
Senior Member
Offline Offline
WWW
« Reply #9 on: August 03, 2005, 08:10:43 pm »
Darrell, got the aluminum carb spacer today and looks great, got tired of cracking the repo spacer when taking the carb off. This is a excellent replacement if you guys are having the same problem. Thanks, Derrick
Logged
OFO2G186791 99.9% Done
picture link
http://www.fordmuscle.com/pictures/derrick/
lm700
I am LAM700.
Member
Offline Offline
WWW
« Reply #10 on: August 03, 2005, 08:14:56 pm »
Excellent, Darrell. Now THAT'S the way to run an airline.
Logged
.M.
webmaster, Mustang Grabber Registry
www.mustanggrabber.com
GrabberGreen
Cool Newbie
Offline Offline
« Reply #11 on: January 11, 2006, 02:56:46 pm »
Can you repost your picture, it is bad.  I'd like to buy a couple spacers too.  You said you made them from Holley spacers, what Holley part number do you use, part # 17-60?
Thanks,
Duane
Logged
Bigdee
Senior Member
Offline Offline
« Reply #12 on: January 11, 2006, 06:22:44 pm »
send me your email address and I can forward it from there! send it to bigdcobra@verizon.net
Darrell
« Last Edit: December 14, 2007, 10:11:25 am by Bigdee » Logged
Darrell
Rick67
Needs A Job
Offline Offline
« Reply #13 on: January 12, 2006, 12:58:07 am »
Are the spacers still for sale?
What email should I use to contact you?
Thanks,
Rick
Logged
Bigdee
Senior Member
Offline Offline
« Reply #14 on: January 12, 2006, 07:23:31 pm »
bigdcobra@verizon.net is my address for the spacers!
« Last Edit: December 14, 2007, 10:11:00 am by Bigdee » Logged
Darrell
Pages: [1] 2  All   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 10.449 seconds with 21 queries.
