Author Topic: Distributor Vacuum Diaphram  (Read 1264 times)
Offline 9F02G221309Garry
« on: August 11, 2003, 06:50:38 pm »
I have recently discovered that the inside diaphram on my vacuum advance is shot. I discovered this while checking the timing and noted that it was jumping from 10 to 20 deg. I would assume that the breaker plate (original distributer) is now able to move slightly since the diaphram is shot. Question!!! Does anyone repair these or sell a good replacement. I suspect that some of you have already had this problem. I have currently degreed the damper to 40deg and adjusted the advance to 37deg at 2500rpm.While the timing floats from 10 to 20 deg at 850RPM..Suggestion anyone.. It seems like it is always something with this car,but you have to love it..
Regards Garry
Offline bosscougars
Vacuum advance rebuild
« Reply #1 on: August 11, 2003, 07:44:52 pm »
Email Brian at fordmuscleparts@adelphia.net
He rebuilds and replates the advances. Tell him Frank sent you.
Offline seventyboss
« Reply #2 on: August 11, 2003, 08:32:42 pm »
Check with Mike Ulrey 727-644-9851.  He is very knowledgeable about Boss distributors, including the vacuum advance.  And will repair them..............Dave
Offline bosscougars
Vacuum advance
« Reply #3 on: August 11, 2003, 09:19:04 pm »
Brian rebuilds them for Mike.
« Reply #4 on: August 12, 2003, 05:05:18 am »
Thanks Frank and Dave. Its good to know I can get this unit repaired. Once again it is great to have access to so many guys with so much knowledge.
Regards Garry
Offline 9F02G196848
  • Global Moderator
    • http://www.boss302.com
« Reply #5 on: August 12, 2003, 08:04:30 am »
Instead of fixing my failing diaphram, I converted the inside of my dist. to a 289 HiPo mechanical advance setup. The problem is the arm on the advance unit is in the way. I found an old advance on Ebay that had the arm already cut and used that and kept my original '69 unit to be rebuilt someday. I got my parts from Mike Ulrey in Fla. I remember the cost being around 20-25 bucks for the parts and about 40 for the advance. I don't remember the cost to rebuild the advance, but I think it's plenty more than that. Anybody know for sure? I did this more for performance than anything.
Randy
Offline bosscougars
Vacuum rebuild
« Reply #6 on: August 12, 2003, 09:05:05 am »
Just talked to Brian and he said he charges $75 to rebuild and replate the vacuum advances. I have had him do several and they look like brand new when done. Mike rebuilds the distributers, carbs. trans.,and more.
« Reply #7 on: August 12, 2003, 10:23:29 am »
Once again you guys came through!!! Thanks Frank for making the call.I will contact Brian and inquire about the turnaround time for the rebuild. The hipo solution is also a option.  Thanks again..
Regards Garry
