Author Topic: Special Tool Needed for Pulling Pilot Bearing  (Read 2881 times)
Offline TXBoss302
« on: February 14, 2011, 10:41:11 am »
Anyone have a good way to pull a pilot bearing from the back of the crank? The one that was installed in my crank is a sealed bearing that is for a smaller input shaft ID. I need to pull it (hopefully without damaging it) so I can put a Ford needle bearing in place.
Do I need a special tool?
69 Yellow Boss 302... Back to not done.... Now back to almost done. Again.
Offline Fairlane514
Re: Special Tool Needed for Pulling Pilot Bearing
« Reply #1 on: February 14, 2011, 10:47:21 am »
They do make a slide hammer tool with a two prong hook, it pulls it in about 30 seconds.
63 Fairlane big block
76 Bronco 347 3 speed
70 Boss 302
65 GTO tripower/4 speed
Offline TXBoss302
« Reply #2 on: February 14, 2011, 10:48:44 am »
Where to get? NAPA or tool truck?
Offline captain morgan
  • 1967 Red Fastback
« Reply #3 on: February 14, 2011, 10:50:40 am »
Fill the hole with thick grease from a grease gun it works the best and find a tool like a socket or extension[fill with grease also] that just fits perfect through the pilot bushing hole and hammer it in and the hydraulic pressure this creates will cause it to come out.
You know why divorces are so expensive ? Because they are worth it! Says me and Willie  Nelson!
Offline TXBoss302
« Reply #4 on: February 14, 2011, 10:59:31 am »
Sounds like a good idea... but I have a feeling I will make a mess.
Offline thebossman
« Reply #5 on: February 14, 2011, 11:39:44 am »
+1
Offline BOSSJIM
« Reply #6 on: February 14, 2011, 12:03:00 pm »
only tools you need are grease..to fill hole behind bearing...a socket that fits into hole...and a hammer. fill socket with grease as well. hydraulics effect pops the bearing out. i've done it this way. guaranteed success.
rags are used to clean up grease.
also, YOUTUBE has some videos posted that show you how. pick one.
  • 1967 Red Fastback
« Reply #7 on: February 14, 2011, 12:18:56 pm »
+1  ;D
Offline David189412
« Reply #8 on: February 14, 2011, 12:36:22 pm »
This method of removing the pilot with grease also works well on the starter bushing on the brush end plate.
David
Offline D0ZZer
« Reply #9 on: February 14, 2011, 01:29:33 pm »
Fill the pilot up with grease
Place a Craftman 3/8 drive 1/2in. 12 point socket on an extention BACKWARD
Insert said socket with attached extention in pilot hole
3 or 4 blows with a 12oz. composite hammer
Clean up grease with 2 or 3 blue Scott disposible paper towels
Replace tools back in tool box
I use the same method for pilot bearings except I use a bushing driver with a washer. The grease shoots back if you use a socket and have needle bearings.
« Last Edit: February 14, 2011, 01:37:30 pm by D0ZZer »
0T02G168802 -sold-
0F02G188028 -sold-
0F02G194284
0F02G204725-finished-sold-
5K43K16097 - B/FX style
Sometimes the best of both worlds is both worlds
Offline Mike367
« Reply #10 on: February 14, 2011, 02:36:35 pm »
I have used this tool from Harbor Freight at least 20 times to pull pilot bushings, it works great and is only $17.00
http://www.harborfreight.com/automotive-motorcycle/pullers/3-jaw-pilot-bearing-puller-4876.html
Mike
Offline bobsboss
« Reply #11 on: February 14, 2011, 02:52:13 pm »
why do you need to replace it?...I would ask the forum if they really understand what this "bushing" is doing...unless you have a bellhousing alignment problem it will last forever...
the oilite/bronze bushing is doing nothing than supporting the transmission mainshaft via the crankshaft until a gear change is made and/or clutch pedal is engaged...it is a bushing only...it is spinning @ crankshaft transmission mainshaft speed...way to many guys are way to focused on this insignificant piece...I have never had any trans/engine problem that related to a pilot bushing!
« Last Edit: February 14, 2011, 03:02:55 pm by bobsboss »
Offline Fairlane514
« Reply #12 on: February 14, 2011, 03:04:01 pm »
Read his original post..........its the wrong size bearing
70 Boss 302
Offline Nitro
  • R.I.P. 12/25/2016
« Reply #13 on: February 14, 2011, 05:24:23 pm »
The grease and hammer deal works the best...
I do not use a socket. One should never beat on
ones tools !!
I use a peice of broom handle ( hard wood ) an
cut it down to just fit the bearing hole. Then pack
the entire area behind the bearing with grease.
It should only take one or hits and the bearing is out.
Nitro.
NITROâ„¢
Offline McBoss
« Reply #14 on: February 14, 2011, 05:42:23 pm »
I also use a wooden dowel close to size.
And yes the bearings do wear out. I have seen them in the past completely oversized and worn.
