Author Topic: Is this a fake distributor?  (Read 11380 times)
Offline Aussie_Boss302
« on: December 03, 2012, 07:18:22 pm »
I’ve read several threads about identifying fake distributors and I must admit I’m pretty confused.  The discussions seem to center around the location of the main wire hole.  At the risk of initiating another flare up, the distributor below came as a spare with my car.  It seems correct (as far as I can tell), but the wire exit hole isn’t close to the cap hold down clamp… supposedly, where the real deal exits.
Does this look like a “reproduction” and if it is where did it come from?
Thanks,
Roy
Offline BOSS-STANG
Re: Is this a fake distributor?
« Reply #1 on: December 03, 2012, 07:32:55 pm »
It looks legit except for the black coil wire coming out of the distributor. It should be closer to the distributor cap clip. Thats some times a give away to a fake but some folks claim some original Boss distributors had coil wires located there.  :-\
Offline D0ZZer
« Reply #2 on: December 03, 2012, 07:35:04 pm »
WOW...They are getting better at these restamps
0T02G168802 -sold-
0F02G188028 -sold-
0F02G194284 - under restoration
0F02G204725-finished-sold-
5K43K16097 - B/FX style-sold
4A66P176359 - 427 A/S style
Sometimes the best of both worlds is both worlds
Offline XB05SX
« Reply #3 on: December 03, 2012, 08:07:15 pm »
if its a spare, or if u didnt pay top dollar, and it works, then i dont see an issue with using it. if u have doubts, then dont sell it, but jsut keep it as a spare or use as ur regular one and put ur legit one away
Offline gt350hr
« Reply #4 on: December 03, 2012, 08:38:00 pm »
   IMHO they are both restamps. The vacuum adavnce mechanisim is FOR SURE and the dist looks like its been altered as well.
      Randy
'66 GT350H (6S477)1of 18 white w/blue side stripes - drag raced mostly w / Boss 302 power for 35+ years
68.5 Cobra Jet fb  white w/blue c stripe 4spd
sorry never owned a Boss car just engines
cover Car Craft July '77 with my Boss powered GT350
cover/article Mustang Illustrated Fall 1987 w/all aluminum SK 351 Cleveland powered Mustang II
cover /article Modified Mustangs Feb 2011
cover Mustang Monthly  June 2014
« Reply #5 on: December 03, 2012, 08:47:35 pm »
I don't intend to sell it, or use it for that matter, and I didn't pay big bucks for it.  I'm just curious, if it's a fake, then someone changed Cxxx to C9ZF... That doesn't look easy.  The "E" and "X12" don't look like the ones stamped on Mustangtek website.  If it wasn't refinished (with visible sanding marks on the housing) I could argue it's the real deal... I can't argue it's the real deal.
Does anyone have a hole correct distributor with stampings similar to these?
Offline Wembley
« Reply #6 on: December 03, 2012, 10:01:34 pm »
Even if you ignore the incorrect hole location, this is a clear restamp.
Offline Danoh1
« Reply #7 on: December 04, 2012, 06:47:46 am »
I don't intend to sell it, or use it for that matter...
So you are going to do what with it?  Looks good, and will work for 99% of the mission 99% of the time.  I'll give you 1 million for it.
1970 M code Boss T/A (ala Dano)  link to racecar
HHP
Offline gt350hr
« Reply #8 on: December 04, 2012, 08:41:09 am »
   Yen?
Offline CaBossFan
« Reply #9 on: December 04, 2012, 08:49:54 am »
Previous posting on Boss 302 distributors:
http://www.boss302.com/smf/index.php?topic=58299.30
Offline JohnSlack
« Reply #10 on: December 04, 2012, 10:12:42 am »
Danoh, I have recently read the microscopic print on your offer and it seems you are really offering 1,000,000 Doll Hairs, not Dollars.
John
1st universal rule of value,
"Parts are parts, cash is only money and doesn't have the same value. You get that right?"
 2nd universal rule of value, "an object is only worth the higher of two values placed upon it by either the current entity in possession of the item, or the value placed on it by an entity wanting to take over possession of the item."
Current;
9F02G217159
0F02G106990
Former;
9R02R122420
9T02M202688
0R05Q147920
0T02G125836
9F02Z159758 KK1383
Offline noboss
  • True BOSS 302 Exhange Enthusiast
« Reply #11 on: December 04, 2012, 11:09:16 am »
Yes the wire hole is too far away from the cap hold down clip.
http://www.boss302.com/smf/index.php?topic=46198.0
Offline Bossssssss
« Reply #12 on: December 04, 2012, 08:10:07 pm »
Yes, the distribiution in the picture is a fake. No doubt about it.
Bossssssss
Offline BOSS-STANG
« Reply #13 on: December 05, 2012, 02:09:28 pm »
If you magnify the E you can clearly see a C stamped under it.
« Last Edit: December 05, 2012, 02:21:33 pm by BOSS-STANG »
Offline sohcammer
« Reply #14 on: December 06, 2012, 12:24:02 am »
Good eye.  The hole location and severe sanding - dead giveaways.
