Author Topic: BOSS 302 SNORKEL TUTORIAL REFERENCE  (Read 14707 times)
Offline shelbyboss302
« on: January 20, 2013, 03:37:03 pm »
In this tutorial, I’m going to try and show you how to correctly identify an original 1970 Boss 302 Snorkel with Ford engineering number D0ZZ-9A626-B. Hopefully this will help the person just starting out in the hobby or some that are already in the hobby and want to reference the correct parts. As to common belief, the 1970 boss 302 snorkel is not unique just to the Mustang and Cougar. The 1970 429 SCJ Torino also sported the Ford engineering DOZZ-9A626-B Snorkel. The snorkel I will use for this tutorial is off a Dearborn Boss 302. This Snorkel is an early take off part with original paint and is a good candidate to reference from as it has never been modified and is the way it left the factory.
        Shelby
INTRODUCTION
FRONT VIEW
REAR VIEW
BOTTOM VIEW AND DIMENSIONS
SIDE VIEW DIMENSIONS
MOUNTING FLANGE
TOP VIEW DIMENSIONS
BOTTOM VIEW
REAR FLANGE
INSIDE REAR
LOOKING AT THE RUNS, THESE SEEMED TO BE DIPPED
BOTTOM STAMP LOCATION
STAMP DETAILS
ART WORK DETAILS
ANOTHER ORIGINAL EXAMPLE
REPRODUCTION
REPRODUCTION
REPRODUCTION
« Last Edit: January 21, 2013, 06:09:13 am by shelbyboss302 »
Offline markboss
  • Bright Yellow Drag Pack...
Re: BOSS 302 SNORKEL TUTORIAL REFERENCE
« Reply #1 on: January 20, 2013, 04:02:21 pm »
THANKS!!!!!
'70 BOSS 302 Bright Yellow W axle
'67 Shelby GT350/Paxton #130
Offline noboss
« Reply #2 on: January 20, 2013, 04:48:46 pm »
Great info and pictures , thanks for doing this and thaks for all you time you spent.
Offline b.guggenmos
« Reply #3 on: January 20, 2013, 05:37:49 pm »
Nicely done! I really enjoy this stuff. Brian
1965 Comet Cyclone 351C, Jerico, 10.94@125
1965 Comet Cyclone all original 4 speed
1970 Boss 302 W Code
1932 Ford 5 Window Coupe "Real"
Offline CaBossFan
« Reply #4 on: January 20, 2013, 05:44:52 pm »
Thanks for the tutorial on the snorkel as I immediately went out to the garage to check out the one on my Boss 302.
Offline mwizz
« Reply #5 on: January 20, 2013, 06:37:34 pm »
That's great thankyou
1970 Mustang Boss 302
1966 Mustang GT Convertible
Offline sportyworty
« Reply #6 on: January 20, 2013, 06:42:58 pm »
Great job Pat
"To steal ideas from one person is plagiarism; to steal from many is research."
8F91R577646 Black/Red 4 speed
Offline Nitro
  • R.I.P. 12/25/2016
« Reply #7 on: January 20, 2013, 07:31:29 pm »
 shelbyboss302
Nice post...
Do you have the same thing for a BOSS 9 ?
Nitro.
NITROâ„¢
Offline fordgt
« Reply #8 on: January 20, 2013, 11:09:23 pm »
Great tutorial.  Thanks for all your effort on this.
fordgt
69 White Boss 302
70 Grabber Green Boss 302
Offline 69MustangMike
    • Infrared & Mold Inspections
« Reply #9 on: January 21, 2013, 09:13:35 am »
Super JOB on that info !!!!!
69 Calypso Corral B302
1970 Grabber Blue B302
1974 GTS Pantera
1970 Challenger R/T
1968 Charger R/T
1969 B302- brother of cc Boss above VIN 216
87 Conv Mustang 5.0
89 Hatchback 5.0
1970 B302 Cougar Eliminator matching #s
"I'm feeling fine in both my 69's"
Offline MD69Boss
« Reply #10 on: January 21, 2013, 11:25:18 am »
Thank you, Pat.
Your time and research is appreciated!
Offline epresher
« Reply #11 on: January 21, 2013, 03:36:58 pm »
Well done!
Offline Hawkrod
« Reply #12 on: January 21, 2013, 04:54:12 pm »
Very well done but I would advise caution regarding the info about spot welds. They vary greatly on original snorkels because they were dependent on how fresh the tips were that were welding them. You will never see blown out ones like shown on the repro but they are not all as nice and crisp as the ones on your snorkel. The spot welder tips wear as they are used and it will depend on how fastidious the worker was on changing them. Also note that as they wear they leave a larger impression that may be shallower and more "puddle like" rather than a nice round divot. I looked at several originals and the size of the spot welds can be the same or vary from each joint and of the dozen or so I just checked they varied significantly. It also actually looks as if they may have made sub assemblies and joined the end to the flange and stepped part assembly because most are different (but not all) and some have the nice spot welds near the air cleaner while the further out ones are "softer". One final detail that many fakes get wrong is the flange that attaches to the air cleaner has a 90 degree edge all of the way around the opening that bolts against the air cleaner body  while ones from other Fords have a small step on the face that bolts to the air cleaner body. This about 1/2 inch wide or so and is actually at the bottom of a regular Ford snorkel and is assembly indexer. When a regular snorkel flange is cut down this step is evident. Hawkrod
Here is a regular 289/302 snorkel where the step is evident at the bottom center of the opening:
Hawkrod
39 Ford Deluxe Coupe
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 Ford F250 4X4 w/460 swap
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
look at my cars past and present at superford!
Offline McBoss
« Reply #13 on: January 22, 2013, 10:33:45 am »
Does any other Ford product have the same snorkle end piece? I have the elbow that connects to the air cleaner but someone cut of the snorkle. Maybe another car has same end piece I could graft on to the elbow?
Offline NZnoboss
  • Livin' the dream in our Grabber Green W code :-)
« Reply #14 on: January 22, 2013, 02:11:22 pm »
Thanks for posting this shelbyboss302.
This makes it so much easier when shopping for a car, knowing what's correct, and what's not. I still have the shifter handle info burned in to my memory. :)
I really appreciate the time you spent doing this.
Cheers,
Bob.
'70 Boss 302 - 0FO2G126086 - GG, shaker, W code.
'95 Falcon XR8 5spd
'88 BMW 535ia
