Author Topic: Vin numbers  (Read 2113 times)
Offline bosscobra
Vin numbers
« on: February 19, 2004, 03:55:58 pm »
I'm looking at 71 BOSS 351's, where do I find the vin numbers? Are they stamped into the block like the 70? On the front fenders? What are the part numbers I need to look for? Any other fundamental characteristic's that should be noted? Thanks!!
Offline boss1ncj
Vin numbers
« Reply #1 on: February 20, 2004, 12:20:29 pm »
All the '71 Boss 351's are an R engine code in the vin, and were only built in Dearborn plant.  The critical data/stampings are all in the same basic places as a '70 Boss 302.  If you ignore the obvious differences in sheetmetal, the basic design and construction is very similar to the '70 models.  In fact, they may have more in common with a '70, than a '70 does with a '69.
