Author Topic: 2013 Boss 302 Oil Filter  (Read 664 times)
Offline 0F02G-1ZVBP
  • Paying the cost of being the Boss ...
« on: November 17, 2017, 07:34:12 pm »
Which is the Ford Racing Filter with extra capacity: FL500S or FL820S?
I believe the service replacement is the FL820S, but you can use the bigger FL500S.
Someone please confirm.
Thanks!
John
jdettori@optonline.net
1967 GT Vert      2001 SVT Cobra
1970 Boss 302    2013 Boss 302 LS #214
1986 SVO
Offline hopey
Re: 2013 Boss 302 Oil Filter
« Reply #1 on: November 17, 2017, 08:36:11 pm »
They are not the same, even though they fit. There are differences in burst rating, bypass valve pressure etc. the 820S is the larger filter. See this...
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2508115
Motorcraft Number FL500s
Part Number: 57502
Principal Application: Mazda Tribute, Ford Escape and Mercury Mariner (2009) w/ 3.0L engine - Ford Taurus, Edge, Mercury Sable w/ V6 3.5L mfg after 1/16/2009
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.09
Outer Diameter Top: 2.942
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Max Flow Rate: 10-12 GPM
Beta Ratio
Burst Pressure
Normal Micron Rating
Gasket Diameters
OD 2.753
ID 2.397
THK 0.25
Motorcraft Number FL820s
Part Number: 51372
Principal Application: Ford/Lincoln/Mercury (91-09), Mazda (00-09), Cadillac STS-V, XLR-V (06-09)
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.66
By-Pass Valve Setting-PSI: 16
Max Flow Rate: 11-13 GPM
Beta Ratio 2/20=12/25
Burst Pressure 275
Normal Micron Rating 19
Gasket Diameters
You can use the Ford Racing filter. CM-6731-FL820. (Not the same as a 820S). It has 283 sq in synthetic media area, flow rate of 13 gpm at 7.3 psi, goes into bypass at 17-23 psi, and has a burst pressure of 626 psi.
1970 Boss 302 red, shaker & deluxe interior!
2013 Boss 302 LS614 Black
2016 F150 5.0 platinum 4x4
2011 Full Fat Range Rover Supercharged
2004 Harley Davidson Fatboy
Bucket list - late 70's Escort RS2000, 04-06 M3
