Author Topic: 1970 Lower Radiator hose frustration  (Read 897 times)
Online Thomas
  • Newbie
« on: August 12, 2018, 04:22:35 pm »
Is there anyone who manufactures / sells the lower radiator hose with the right bend that fits a 302 Boss 70? Have tried with two "concours" from NPD but failed to get them free from the power steering belt . Seems to be a common problem with the aftermarket lower hoses !
// Thomas
Offline crossboss
Re: 1970 Lower Radiator hose frustration
« Reply #1 on: August 12, 2018, 05:05:49 pm »
Try using a 1970 351W lower hose. They are a bit longer and have a more pronounced 'bend' away from the power accessories.
Current lifelong projects:
1969 Mustang Fastback/FOX chassis, 6 speed, 4 wheel discs, with a modern Can-Am 494 (Boss 429), Kaase headed, intake mounted with a 1425 cfm 'B' Autolite Inline carb, ala Trans-Am style…Whew!
Volvo 1800, being converted to Boss 302 power…coming soon!
Offline 167961
« Reply #2 on: August 12, 2018, 08:43:11 pm »
The lower hose is always a tight fit in that area. However, if you buy one of the Marti hoses you will find it takes very little fiddling to get the hose to clear the belt ;-)
Martin
June 1970 VIN 0T02G167961, all numbers matching, not yet perfect but therein lies the challenge :-)
Offline GGBAAS
    • http://www.cardomain.com/memberpage/689921
« Reply #3 on: August 12, 2018, 11:02:58 pm »
I replaced by original lower hose with a ford approved replacement.  Perfect fit.  I think it may have been scott drake.  I don't think it was from kevin marti.
Dearborn, 1970 April build
Offline BOSS-STANG
« Reply #4 on: August 13, 2018, 08:34:09 am »
I have the same problem. Not with my Boss as it doesn't have P/S but my 70 351C Mach 1 does. The repo replacement lower rad hose gave me the same problem. The P/S hose rubbed against the hose and it began leaking. I had to reinstall the original factory hose which is still in good shape but its 48 years old. The repo hoses don't have the slight clearance jog near the water pump outlet. I went to Auto Zone and got a 351W replacement hose and it does have the jog at the water pump end. Haven't tried it yet but it appears it will work.
Offline 69MustangMike
    • Infrared & Mold Inspections
« Reply #5 on: August 13, 2018, 10:46:02 am »
I would also try Marti, maybe a slight trimming on the hose and final question do you have the correct radiator installed?
69 Calypso Corral B302
1970 Grabber Blue B302
1974 GTS Pantera
1970 Challenger R/T
1968 Charger R/T
1969 B302- brother of cc Boss above VIN 216
87 Conv Mustang 5.0
89 Hatchback 5.0
1970 B302 Cougar Eliminator matching #s
"I'm feeling fine in both my 69's"
Offline app01
    • Custom car showboards
« Reply #6 on: August 13, 2018, 10:59:23 am »
I have the Marti hose and it fits pretty good. No trimming was needed, but did have to rotate it slightly to find where it cleared the PS belt the most. There is about .75" clearance between the hose and belt.
See pic below.
Build Pics:
http://www.palmiericoncepts.com/My-Mustangs/1970-Boss-302/1970Boss302.htm
Boss 460 Build- http://www.palmiericoncepts.com/My-Mustangs/1970build/Final-Build.htm
Currently own:
1970 Boss 302 - Yellow- May 1970, Dearborn
1970 Mach 1 w/ Ford Racing Boss 460ci -best so far is 9.911 @136.86
1962 Corvette Convertible 327/340hp
Others:
1967 Mustang Convertible (My 1st car)
1970 Mach 1 (my 2nd car)
1989 GT- New, daily driver
1969 Mach 1 (<29k miles, Unrestored, MCA Gold)
MCA #62598
www.PalmieriConcepts.com
Online Thomas
  • Newbie
« Reply #7 on: August 13, 2018, 11:51:12 am »
Yes the radiator is correct !
Offline jrboss
« Reply #8 on: August 16, 2018, 03:32:25 pm »
I have the same issue,I will take the advise from crossboss and Boss-Stang  Thanks... 351W lower hose should work.
Offline jrboss
« Reply #9 on: August 28, 2018, 07:33:19 pm »
The 351W Lower hose did work,I had to trim a little over and inch but it went in and now clears the lower belt,by two inches.
Thanks for the tip
Offline jrboss
« Reply #10 on: August 28, 2018, 07:44:09 pm »
Make sure you have a spring in the lower hose,because of the sharper bend.
Online Thomas
  • Newbie
« Reply #11 on: August 29, 2018, 12:20:10 am »
Yes, a spring may solve my problem. I managed to get the hose free from the belt, but then I got a sharp bend on it.
I'll try a spring.
Thanks for that tip !
Offline RadBOSS
  • True BOSS 302 Exhange Enthusiast
  • A/S Solo I RIR Turn 6, 1973-4
« Reply #12 on: September 09, 2018, 11:16:20 pm »
Martin
I too endorse the Marti hoses.  Perfect fit on my 69
1929 Model A Roadster
1969 BOSS - original owner
1987 Merkur Xr4Ti (with Sierra Cosworth body kit)
2005 Jeep LJ
2012 GMC Yukon XL
2016 Shelby GT350R
"Good judgment comes from experience, and a lot of that comes from bad judgment. " - Will Rogers
"Whether you think you can or think you can't, you are right." - Henry Ford
"Anything worth doing, is worth doing right." - Unknown
