Author Topic: 70 mustang parts  (Read 1145 times)
Offline Butch351
70 mustang parts
« on: April 06, 2019, 01:04:14 pm »
Will 70 mustang carb &distribitor  work on 71 boss
Offline crossboss
  • ^My Old Heap Boss 302…aka S-B Racing!
Re: 70 mustang parts
« Reply #1 on: April 11, 2019, 06:56:35 pm »
Any 351 Cleveland (not Windsor), or 429/460 distributor will work. Stock Boss 351s used a 'spread bore' carb, unless you are using an aftermarket Holley/square bore intake.
Current lifelong project:
1969 Mustang Fastback/FOX chassis, 5 speed, 4 wheel discs, with a modern Can-Am 494 (Boss 429), Kaase heads, intake mounted with a 1425 cfm 'B' Autolite Inline carb, ala Trans-Am style…Whew!
Offline Butch351
« Reply #2 on: April 12, 2019, 07:09:09 pm »
Thanks for info !
Offline hotrodford
« Reply #3 on: April 13, 2019, 08:03:41 pm »
A Holley carb will bolt right on the B351 intake.  The B351 spread bore intake uses a square bore bolt pattern.  The primary bores, in the intake, are slightly smaller that a square bore intake, however, so a thick carb gasket is necessary to raise the throttle plates just a bit.
