Author Topic: Oil  (Read 217 times)
Offline Butch351
Oil
« on: August 06, 2019, 06:07:32 pm »
What oil are you guys use , am driving not trailering to shows
Offline d1boss
Re: Oil
« Reply #1 on: August 08, 2019, 02:23:21 pm »
I’ve used for sometime now Brad Penn. The green oil. it has good levels of zinc which is ideal for flat tappet cams.
Bruce
Offline AlexM
  • Chippewa Falls Wisconsin
Re: Oil
« Reply #2 on: August 09, 2019, 08:33:40 am »
I've been running Mobil 1  15W-50  for the last several years. Their product information sheet notes 1300 PPM zinc levels as well as 1200 PPM for phosphorus specifically for the 15W 50 weight.
--Alex
1969 Mach 1
1970 BOSS 302 0F02G120146
1970 BOSS 302 0F02G119233 W code
1969 BOSS 302 9F02G196425
1969 BOSS 429 9F02Z198888 KK 1982
Offline d1boss
Re: Oil
« Reply #3 on: August 09, 2019, 07:56:16 pm »
Hey Alex, is that a fully synthetic? I was using that maybe 20 years ago, thinking I was doing the best I could, on an engine I treasured. And it used oil so I switched to Brad Penn ever since with better results (excuse the lack of specifics, it was some time ago)
Do you find that?
Bruce
Offline AlexM
Re: Oil
« Reply #4 on: August 11, 2019, 06:26:55 pm »
Hi Bruce, Mobil 1 15W/50 is synthetic.  I can't really say about the usage as I'm running it in cars that don't get a lot of miles, maybe several hundred a year,  so I change oil just based on time not mileage. I think every Ford I've ever owned was down a quart at 3000 miles ;) but these cars are getting less typically than a 1000 miles on oil changes..
--Alex
1969 Mach 1
