Author Topic: Engine Date Code Location  (Read 697 times)
Offline Jeffrey
« on: August 28, 2019, 02:02:51 pm »
Where is the engine block date code location for a 69 B9?
Jeff
Offline AlexM
  • Chippewa Falls Wisconsin
Re: Engine Date Code Location
« Reply #1 on: August 28, 2019, 02:28:30 pm »
I'm not 100% sure but I think it's in the lifter valley...
--Alex
1969 Mach 1
1970 BOSS 302 0F02G120146
1970 BOSS 302 0F02G119233 W code
1969 BOSS 302 9F02G196425
1969 BOSS 429 9F02Z198888 KK 1982
Offline BOSSHEMI
« Reply #2 on: August 28, 2019, 04:01:52 pm »
Casting date is in lifter valley. Assembly date is to the left of water pump below cylinder head on block face.
KK1336 Royal Maroon 820S
Offline Jeffrey
« Reply #3 on: August 28, 2019, 04:10:22 pm »
Is the assembly date cast or punched?
Jeff
Offline AlexM
« Reply #4 on: August 28, 2019, 05:31:06 pm »
That one is punched by hand.
--Alex
1969 Mach 1
Offline Jeffrey
« Reply #5 on: August 28, 2019, 07:44:52 pm »
Thank you for the information.
Jeff
Offline ed meyer
« Reply #6 on: August 28, 2019, 10:02:39 pm »
Lima ohio engine plant assembly date hand stamped on RH  (passenger side) front of block between timing chain cover and head.
Offline KKKen
« Reply #7 on: August 29, 2019, 07:03:33 pm »
I can barley make out the assembly date on my engine, it looks like 4 numbers, it would help if I knew the sequence of numbers. Is the first number the year? Thanks KC
69 Boss 429 Unrestored KK-1416
Offline AlexM
« Reply #8 on: August 29, 2019, 07:29:31 pm »
Typical Ford date code stuff; Year, Month, Day
Here's mine 9F18,  Year=1969, month F=June, Day=18th    18-Jun-1969
Looks like the 1 and 8 are upside down and I image the Z is obvious :)
Just a few days ahead of the cars actual build date, 24-Jun-1969
--Alex
1969 Mach 1
Offline KKKen
« Reply #9 on: August 30, 2019, 07:04:36 am »
OK Thanks, My numbers are barley visible with all the paint and I do not want to scrape it off. My car was built 2/24/69 and it looks like the stamping is 9B 20.
For some unknown reason I can`t upload pics to this site any longer. KC.
