Author Topic: B.F. Goodrich Space Saver Spare - F78-14 - $475  (Read 867 times)
Offline Jeffrey
« Last Edit: December 15, 2019, 02:19:52 pm by Jeffrey »
Jeff
Offline McKeever
Re: B.F. Goodrich Space Saver Spare - F78-14 - $500
« Reply #1 on: September 25, 2019, 05:18:37 pm »
FYI
The double valve stem is not correct for 69 and 70.
Owned my BOSS since March 1974.
0F02G154740 Dearborn 1-16-70
Honesty is doing the right thing with a witness.
Integrity is doing the right thing without one.
Ken Miles "There's a point 7000 RPM is where you need it"
Offline myboss
« Reply #2 on: September 26, 2019, 03:39:14 pm »
  HHMMM    The double valve stem is exactly like the one on my original BOSS spacesaver.
I have owned this car since January 1977
Offline McKeever
« Reply #3 on: September 26, 2019, 05:18:22 pm »
I can guarantee, and so can Many others here..no 69 or 70 Mustang came with the double valve stem.
The double valve stem did not come out in till 72 or 73.
Offline 70cj428
« Reply #4 on: September 26, 2019, 09:56:42 pm »
Just FYI, tire is dated the 30th week of 1975, The  "DOT" Tire Identification Number on the tire was standardized and became a requirement in March, 1971 so if the tire has "DOT" above or before the number, it's 1971 or newer.
Offline ablue69
« Reply #5 on: September 27, 2019, 03:55:31 am »
What was the purpose of a double valve stem?  Just curious.
'64 1/2 Convertible (SOLD)
'64 1/2 hardtop
'66 Bronco, 5.0 fuel injected, restomod
'67 Mustang Junior!
'68 Bronco Half Cab
'69 BOSS 302  9F02G196425 (SOLD)
'74 Bronco 302 auto
'89 Saleen (bought new, never modified!)
'96 Bronco XLT
'08 F350 Lariat Crew Cab dually
'16 T350 Transit Cargo Van dually
Norm
Offline 70cj428
« Reply #6 on: September 27, 2019, 05:13:14 am »
Quote
If I'm not mistaken ......  It's a pressure relief valve to prevent over inflating the tire. Apparently there were issues ....
Some tires have two separate holes and stems, then it seems they went to the metal twin stem thing. All the original 69/70 tires I've seen used a single standard stem....
Offline McKeever
« Reply #7 on: September 27, 2019, 09:35:20 pm »
70cj428,
Never knew about the "DOT" (Department of Transportation) thing, Very cool!
Thanks for sharing that.
Just to add....there were problems with the early Space Saver Spare.
People were sometimes injured while inflating the spare with the canister. Remember Ford was not the only one using the Space Saver.
This caused Ford to send a letter in the mail to All Registered Owners that explained that the Space Saver Spare tire MUST be mounted to the car Before inflating. A yellow with black printing stick and peel label was included and Read:
1. Peel carefully from this corner.
2. Mount the label on the Space Saver Spare "TM" wheel near valve in clean,dry area.
I remember getting the letter in the mail, I think in 74, I put the sticker on the rim and it's still there. Have the mounting instructions of the Beer fridge door, but the yellow has faded out.
Got what's left of the build sheet, got the buck tag...so why the Hell did I not save this letter from Ford......... talking to my buddy and member "Metalmovers"  it's because we were into Racing them.
We never thought about collecting or restoring them.
Offline Dashmore
« Reply #8 on: September 27, 2019, 09:53:55 pm »
I was told you could bring your space saver into the dealership back then and they would put the double stem in your original as a safety recall service.  I was told this but I cannot confirm its validity as I was about the size of a space saver when this all supposedly happened.
Dan
Offline ablue69
« Reply #9 on: September 28, 2019, 03:47:57 am »
Thanks for the info, I'd never heard of the double valve deal.
'64 1/2 hardtop
'67 Mustang Junior!
'68 Bronco Half Cab
'74 Bronco 302 auto
'96 Bronco XLT
Norm
Offline svo2scj
  • Yeah it's the wrong paint and cap!
« Reply #10 on: October 01, 2019, 02:44:45 pm »
Dan
That is correct and the YELLOW tag installed they shown how it worked.
Mark Haas
517 861 7630
Offline myboss
« Reply #11 on: October 05, 2019, 04:56:25 pm »
Well I checked the space save in my car for the word DOT on the tire, none anywhere. Have owned this car since January or 1977, and it has been in the car the whole time. And yes it does have the double steel valve stem. So I'm guessing it was a recall thing ????
Offline Jeffrey
Re: B.F. Goodrich Space Saver Spare - F78-14 - $475
« Reply #12 on: December 15, 2019, 02:20:30 pm »
Reduced to $475
Jeff
